It is currently Mon Aug 25, 2025 1:27 am
 Post subject: Rasp Advice Please....
PostPosted: Wed May 01, 2013 12:46 am
I'm carving a lot more necks these days than I used to. I'm finding it a bit more of a grind than it feels like it needs to be. Right now I'm using Nicholson #49 + #50 rasps. They're ok ( and probably worn out), but I'm thinking an upgrade may be in order. The dragon rasps from stew mac ( I think) and the huge expensive ones from Lee Valley both look tempting. But they're pretty expensive. I have no problem spending the money if its worth the dosh though, but I wonder what the best option might be, and if anyone has any other recommendations....
Thanks!
PostPosted: Wed May 01, 2013 1:17 am
First name: Jim
Last Name: Kirby
I like my Auriou rasps - I do all my neck shaping with them aside from some work lengthwise with a low-angle Lee Valley shave. They are way above the Brazilian Nicholson's that are available now. Yes, they are expensive.
Jim Kirby
kirby@udel.edu
PostPosted: Wed May 01, 2013 2:19 am
First name: Martin
Last Name: Taylor
City: Central Coast
I use very old rasps that have been in my family since the 1850's. The steel in them in fantastic and they still do a great job. Cost me nothing, but I love them. Maybe look in some swap meets for old steel.
Martin Taylor
http://martintaylorguitars.com.au
PostPosted: Wed May 01, 2013 3:23 am
First name: Tom
Last Name: West
State: Nova Scotia
I use the Stew-Mac Dragon rasps and find they are excellent.
Tom
PostPosted: Wed May 01, 2013 6:16 am
Jim,
Which Auriou rasps are you using?
Many Thanks,
Dan
Dan
PostPosted: Wed May 01, 2013 6:46 am
First name: micah
Last Name: medlong
City: parma
State: ohio
Zip/Postal Code: 44129
I love me dragon rasps!
PostPosted: Wed May 01, 2013 9:11 am
Thanks folks....
PostPosted: Wed May 01, 2013 9:46 am
First name: Jim
Last Name: Kirby
DanR wrote:
Jim,
Many Thanks,
Dan
You caught me about 3700 miles from home - I'll check when I get back. The 10RH that Todd said but I use two others as well.
Jim Kirby
kirby@udel.edu
PostPosted: Wed May 01, 2013 11:06 am
Last Name: Sollod
Anybody like Surform rasps? I do.
www.swiftcreekguitars.com
PostPosted: Wed May 01, 2013 11:27 am
First name: Mark
City: Concord
I'm using the Iwasaki rasps and floats, an antique 49 and 50 and a Vixen for various shaping and smoothing.
I sent the 49 and 50 to Boggs Tool and File in Los Angeles and they came back very sharp.
http://www.boggstool.com/ They have a new customer special right now and will sharpen one rasp or file free. Their price on a 49/50 style rasp is normally $8.50 which isn't bad for a better than new cut. They also have very good pricing on new files and rasps.
Last edited by Mark Fogleman on Wed May 01, 2013 12:39 pm, edited 1 time in total.
PostPosted: Wed May 01, 2013 11:59 am
I finally tried the Gramercy cabinet files last year, I like them. Clinton
PostPosted: Thu May 02, 2013 6:59 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I just got this from The Best Things. It's their 12" 8-grain cabinet rasp, about $105 delivered
I haven't used it yet but think it will work well.
Here it is pictured next to a Nicholson #49.
Kevin Looker
I'm not a luthier.
PostPosted: Thu May 02, 2013 10:20 am
First name: Patch
Last Name: Rubin
i have the auriou combination 5 & 9 grain and the roughing rasp. i got the roughing rasp because they mentioned it was good for guitar necks but i find that i use the combination a whole lot more. the roughing rasp is just that, it's really rough and takes away a lot of material. perfect if you are trying to copy sam maloof but maybe not the best for guitar necks.
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
PostPosted: Thu May 02, 2013 3:14 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
The dragon rasps are really good. I also use a farrier's (sp?) rasp that I bought from a farm supply store. It works really well for rough shaping the neck, it is super sharp and has a medium/fine side and a coarse side. Then the dragons are great for finer work and shaping the heel.
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Thu May 02, 2013 4:13 pm
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
Not alot of experience on guitar necks but have used a few rasps/files/floats. Right now you just can't beat the performance to cost of a Iwasaki. As Todd said, they have a slight learning curve but once you get past it they really are nice to work with. They can be very aggressive when you want them to be and a little less depending on your touch. But the surface they leave behind is typically much smoother than if a rasp hit it. They are almost planing the wood not abrading it like a rasp.
Auriou are really nice though and are very easy to use. They are def my favorite rasp. Gramercy tools rasps are also nice to use, not a nice as an Auriou or Liogier. Lioger rasps are exceptional as well. Are not easy to get although that may have changed since I last looked into them. I've used them a few times at a friends and they are as nice as Auriou's.
I've used Lie Nielsen floats a lot for making a set of moulding planes and these are also very nice, but a completely different animal. I would probably not use them on neck carving but they may work fine. The nice thing about them is that they are easy to sharpen yourself.
If you are on a budget I would highly recommend you check out the Iwasaki's, and even if you have no budget I still would recommend them. But if you want nice hand stitched rasps I would first check out Liogier, and then Auriou.
PostPosted: Thu May 02, 2013 5:34 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
FWIW according to The Best Things, their rasps are made by former Auriou employees. They are stamped with FRANCE, the grain size, and TBT TOOLS, obviously a custom run. I bought it because it was about 30% less than an Auriou, & I've had great experience in dealing with The Best Things. If it turns out to be a POS, I'm sure they'll do everything to make things right.
Like I said above, I have not used this rasp yet (hopefully next week) but it looks very comparable to my Liogier model maker's rasp, just a lot bigger.
If any of you want to pursue a Liogier rasp, here's his site http://www.hand-stitched-rasp-riffler.com/
Noel is a good guy!
His prices are very competitive but shipping from France is not cheap & you're not going to get it in 2 days, but they are very nice tools.
Kevin Looker
I'm not a luthier.
PostPosted: Thu May 02, 2013 6:27 pm
State: Tennessee
Noel is a good guy!
Kevin Looker
Just in from Liogier, and knocked out a persimmon pyramid bridge (one end anyway) really fast, What I equate as having the right tool for the job. I used the 6" cabinet makers rasp #14 stitching size laughing6-hehe
Also got a 10" cabinet makers #12 and a 6" square #12. I have the dragon rasp and they are great, but wanted a little finer cut for finishing. Quite a bit cheaper than the Auriou, it took a month from when I placed the order to delivery.
PostPosted: Thu May 02, 2013 10:07 pm
Last Name: jennings
City: Lopez Island
Zip/Postal Code: 98261
I'll Second the Liogier recommendation.... really wonderful tools. MJ
PostPosted: Sun May 05, 2013 10:46 am
So, lee valley has the auriou rasps. They're expensive but seem to be available quickly. However, I have to wonder, are they that much better than the Dragon rasps? You can get the set of dragons for the price of one auriou....
PostPosted: Mon May 06, 2013 1:08 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I'm a big fan of the the Microplane woodworking rasp. The flat and rounded ones....Mike
PostPosted: Mon May 06, 2013 11:59 am
Does anyone have all of the Dragon rasps? If I were to get just one, which one would you recommend (if using/not using a spokeshave)?
PostPosted: Mon May 06, 2013 12:19 pm
First name: Mark
City: Concord
I don't know where you live but Lie-Nielsen has handtool events scattered across the US and usually has a rep from Auriou attending.
http://www.lie-nielsen.com/?pg=1
PostPosted: Thu May 16, 2013 5:04 pm
What is the comparable grain number for an Auriou Rasp compared to a Nicholson 49? The Nicholson is all I have used and I would like to get something a little bigger (from Auriou) but with the same sort of cut..
Thanks, Peter
PostPosted: Thu May 16, 2013 6:31 pm
First name: Jim
Last Name: Kirby
I always thought the 49 was too course to do anything with - always went to the 50 right away. My largest Auriou is a 10, with a cutting surface length about an inch shorter than a 49 or 50, and I'd guess the tooth size is about 1/2 of the tooth size on a 50.
I use that for the heaviest work of neck shaping.
Jim Kirby
kirby@udel.edu
PostPosted: Thu May 16, 2013 7:01 pm
I can't add to what the rest have said regarding the better rasps except for this;
I use a cheap $8 rasp to carve my necks, and it works well for me.
However, I have enough experience in metal work using files to know that the better ones are well worth it. If I can ever afford to I'll upgrade, and I don't think you'll ever regret doing so as well.
